Name that device!
Discussion in 'Archived Threads 2001-2004' started by Jereme D, Feb 16, 2002.
  1. Jereme D
    Jereme D Stunt Coordinator
    Jan 29, 2002
    211
    I need to know the name of the little connectors that go on the end of wires that hook into the spring type speaker terminals. I've tried just searching for banana plugs, but those that I have found so far have been too big.
  2. Dan Hine
    Dan Hine Screenwriter
    Oct 3, 2000
    1,312
    Jereme,
    They are called pin connectors. My experience with them has not been good, however. They don't stay in the spring clips very well at all and offer much less contact area. Hope that helps.
    Dan Hine
  3. Jereme D
    Jan 29, 2002
    211
    I actually thought about that since they are round.
    What if I put a spade connector on the wire and cut off one prongs of the spade so that it would fit into the spring clip?
    I've always thought that spring clip connections were unprofessional looking, but I've never seen anything around other than those pin connectors for cleaning it up.
  4. Dan Hine
    Oct 3, 2000
    1,312
    Hmmmm, from the spades I have seen I am not sure that your idea would work. I think the spade (even just one side of it) would be to wide to fit. I feel your pain as I don't much care for spring clips either. My recommendation remains the same though, just use barewire. [​IMG] Hey at least it won't be in a place were everyone can see it, right? [​IMG]
    Dan Hine
  5. Chuck_C
    Chuck_C Stunt Coordinator
    Oct 31, 2001
    67
    Just solder the ends of the wires. And then maybe flatten them a bit. The cost is right.
  6. KeithH
    KeithH Lead Actor
    Mar 28, 2000
    9,413
    I've always used bare wire with spring connectors. It worked well enough.
  7. Earl Simpson
    Earl Simpson Supporting Actor
    Jan 12, 2002
    803
    Keith is right! Don't get too fancy. Stick zeeeee wire in zeee hole and forget about it![​IMG]
