Kevin. W
- Oct 27, 1999
Recapping my issue with my NAD T773:
Unit would exhibit an excess of hiss and hum after sending a signal to the unit via optical from my DVD or cable box. Tried everything to remedy the problem but nothing worked.
After some communication with the wonderful people at NAD I decided to drive down to Lenbrook head office to take the unit in for repair. Got the bright idea during the drive to ask if the unit could just be swapped for a new one since it was still within the 30day purchase window. I figured they would tell me to go through the dealer for that, but wouldn't you know they gave me a new unit. The customer service that I experienced today was above and beyond what I could have expected. As soon as I got the new T773 home, I hooked it up to my setup and all is working perfectly. Now its time to do some serious movie watching.
On another note, while I was waiting for the new unit, I was told that if you only use the receiver in 5.1 mode that you can use the Back L/R channels to bi-amp the front L/R. Since I have the splitters/inteconnects and wire available from my last setup, I think I'll give it a try.
Kevin
Kevin
