Eddie Wimberly
- Dec 25, 2001
I have the JBL N24 Speakers. I've having a nightmare of a time trying to find the speaker stands and mounts that I want.
I'm looking for a pair of mounts that will allow me to mount 2 of these on the wall directly behind my couch. The only problem is, I want to have the speakers pointing toward one another. I purchased the omnimount 25RWX, but the thread on the mount is too small to screw into the bottom of the JBL N24's, and the bar is not long enough to allow the speakers to rotate 90 degrees (allowing them to point to one another). There is a larger model of the 25 RWX. I want to know the measurements of these mounts, specifically the size of the screw that is on the arm that extends out. If it fits the hole on the bottom of the N24's, I'm set.
Also, I need a pair of stands for my front speakers. Jbl makes a pair, but they do not state how tall they are. I'm looking for adjustable stands so I can get them the same height as my center speaker. So, I started to look for adjustable stands. So far, all the stands I have seen require drilling into the speaker to get it to stay on the stand. Is there a stand out there that is adjustable AND has a way to connect to a N24 without drilling into it?
Please help me with this. I am going crazy trying to solve this dilemma. I have had my speakers sitting on my couch for a week because I can't find the right stuff to mount them properly.
