N24 speakers stands?
Discussion in 'Archived Threads 2001-2004' started by KyleRoussel, Apr 9, 2002.
  1. KyleRoussel
    KyleRoussel Stunt Coordinator
    Nov 24, 2001
    99
    Do these things exist? Or is it "wall mount or bust?"
  2. Phil Iturralde
    Phil Iturralde Screenwriter
    Oct 7, 1998
    1,867
  3. KyleRoussel
    Nov 24, 2001
    99
    Thanks alot!!!
  4. JasonS
    JasonS Stunt Coordinator
    Sep 5, 2000
    107
    Kyle, I was at Lowe's this past weekend, and they had some plant stands that I'm thinking of buying as speaker stands. They were unfinished, and require assembly. They came in 25in, 31in, and another height I don't remember. They were price each, but I'm only sure the price of the 31 in ones. They were $25 each. They were also pretty high in WAF, in case you need to take that into consideration.
  5. KyleRoussel
    Nov 24, 2001
    99
    Plant stands huh? Clever, how exactly does it work? Do you use velcro, and what does WAF mean?
  6. JasonS
    Sep 5, 2000
    107
    I haven't actually bought them yet, but I was thinking of using velcro. Just have to figure out how to finish them first.
  7. David_Stein
    David_Stein Second Unit
    Feb 13, 2002
    422
    WAF = wife acceptance factor, also known as Spouse Acceptance Factor (SAF)
  8. Hank_P
    Hank_P Second Unit
    Nov 15, 2000
    321
    19
    110
    WAF/SAF = The Master
  9. KyleRoussel
    Nov 24, 2001
    99
    [​IMG] Now THAT is hilarious!
    Thanks guys!
  10. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    I just built some custom speaker stands for my JBL S38 bookshelfs. I decided to make the speaker stands "bookshelfs" themselves to serve economical purposes.
    Materials used:
    3/4" sheet MDF $20 at home depot
    16 2" screws
    A bunch of Nail gun shots
    A bunch of staple shots
    Some beads of carpenters glue
    bondo to seal screw and nail holes
    Flat black paint and sponge brush ($6 paint, $.58 brush)
    20 stainless steel pegs for shelfs
    stips of Mahogany for back stops to shelfs
    The height is 24", width is 17", depth 11"
    If you can access a shop, it will be easy...
    My web site with speaker and room pics: http://www.angelfire.com/sports/RCcars/speaker.html
