N00b article on video connections
Discussion in 'Displays' started by Harold Wazzu, Apr 12, 2004.
  1. Harold Wazzu
    Harold Wazzu Supporting Actor
    Oct 1, 2003
    885
    I was trying to understand just what component video connections were since I don't have an HDTV yet and came across this article.
    http://reviews.cnet.com/4520-6463_7-...ml?legacy=cnet
    Gives a simple explanation of the 3 most common types of video connections. Thought it might help someone else as well.
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Yes, though definitely DVI is something to look into more and more nowadays if you have a digital display device.
    And I also should mention RGBhv, since with more HTPC use, that too is important to know about as well. Especially since I use RGB, since that's all my projector takes. (well, it takes composite/s-video, but you'd never want to feed it that!)
