N Center as a rear center???
Discussion in 'Archived Threads 2001-2004' started by Brad A, Mar 11, 2003.
  1. Brad A
    Brad A Agent
    Nov 15, 2001
    45
    What do you think about using a JBL NCenter as a rear center speaker...I'm replacing my NCenter with the S Center and figured I might as well try the N Center as my rear center...Any comments on this? I have S38's up front and N24's as rears now.Thanks for some input
  2. Ben_wood
    Ben_wood Stunt Coordinator
    Jun 21, 2002
    234
    Brad, that seems like a good idea to me. The rear speaker is less critical so using a lower quality unit there shouldn't be a problem. I'm assuming that the N and S families are close enough in tonal qualities that this would be a good match.
