Myth or fact is upgrading from a Coaxial cable to a better one make a difference..
Discussion in 'Accessories, Cables, and Remotes' started by EddyObregon, Feb 13, 2004.
  1. EddyObregon
    EddyObregon Stunt Coordinator
    Jan 12, 2004
    153
    I have a 3 year old Monster data link 100 and I just ordered a coaxial cable from better cables.com that i heard is top quality will that make a difference in sound. IS this myth or fact that upgrading from a fiber ptic cable or coaxial to a better one make it better.
  2. Justin_D
    Justin_D Stunt Coordinator
    Dec 27, 2003
    217
    Can a cable turn 1s and 0s into better 1s and 0s?
    I don't think so.
  3. Michael__M
    Michael__M Stunt Coordinator
    Jan 12, 2004
    167
    From what I've been reading here it will only make it better if you currently have a faulty cable or you are picking up noise in your current cable. The Coax is shielded better against the types of interference you could pick up in your system. This would be expecially true for longer runs. Just think of it as nice insurance just in case. BlueJeans makes nice cable. Now I did borrow a coax sub cable for a few days and it got rid of the hum my sub was making. I plan on making coax interconnects for my sub and video this weekend or next.
  4. Shane Martin
    Shane Martin Producer
    Sep 26, 1999
    6,017
    Eddy,
    Listen and let us know. You'll get more opinions than answers on that question because there is no definitive answer.
  5. Brian L
    Brian L Cinematographer
    Jul 8, 1998
    2,937
    24
    1,610
    Myth.
  6. BurtS
    BurtS Stunt Coordinator
    Feb 1, 2004
    60
    I think im running a rca as my coaxial is this ok?
  7. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    If it's shielded and a reasonable length you're OK. As with all cables, excercise a bit of care in their insertion and removal and general handling.
  8. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    All good interconnects are coaxial. But some subwoofer cables have little arrows showing direction. This is not just hype - there is something different at the destination end.
    A "Subwoofer" cable with arrows does not have the mesh shield connected to the RCA plug on the destination end. This removes the dredded "ground loop" hum. This is because the shield on a coax cable is used to connect the signal ground (0.00 volts) between your electronics.
    A subwoofer is a bit unique: it has a 3-prong AC power plug. So does your reciever, but nothing else does. This means the amp and the subwoofer "Fight" over who owns the 0.00 volt reference. Using a subwoofer cable without the shield connected at both end breaks the fight. Try this if you are making your own cable.
  9. BurtS
    Feb 1, 2004
    60
    Do the expensive gold rca's make a difference in sound quality?
  10. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    The gold plating is only a few mils thick and is done to prevent corrosion problems and provide an attractive exterior. Nonetheless, gold, being a relatively soft metal, can wear off with repeated removals and insertions. Consider buying some inexpensive contact cleaner/lubricant (caig.com has a nice assortment of little bottles that do good things...don't like them, then buy someone elses) and using a swab clean your contacts every now and then. As to a difference...nope...could've used nickel, silver, chromium, brass, rhodium, etc.
  11. Brad_Harper
    Brad_Harper Stunt Coordinator
    Jul 5, 2001
    132
    Upgrading to a more expensive digital cable will not affect your sound quality. Any old rca cable will do. Shielded is a good idea but not always necessary. Digital signals are pretty robust at rejecting any noise. If you are getting sound out of your receiver from your CD/DVD player without any problems then whatever cable you're using now is fine. There is a detailed thread in the Power amp forum about this topic. Good wine tips as well. [​IMG]
  12. John Royster
    John Royster Screenwriter
    Oct 14, 2001
    1,088
    its all about the bandwidth. So yes, a "better" coaxial cable can make the data more closely resemble what is output from the transmitter if the rated bandwidth is higher.
  13. ChrisHeflen
    ChrisHeflen Supporting Actor
    Sep 9, 2002
    912
    Ok, my turn please!
    I was given a set a of Monster Video 3 or 300 something or other component video cable.
    I seperated the three and run two for analog audio and the other one for the video for my dvd player. Is this ok? Are they 75 ohm?
  14. John Royster
    Oct 14, 2001
    1,088
    LOL! That' what a forums for...jump right in!
    Sure you can run like that. Any video cable will (well, it'd better be) 75 ohm coax.
  15. Jan H
    Jan H Cinematographer
    Nov 6, 2001
    2,007
    I'm a firm believer that cables make a difference, if only because I try to do exhaustive listening and comparing. Example: on my setup, the Kimber D-60 Illuminati brought out far more detail, resolution, and bass response than the Digiflex Gold II I was previously using. And for a hundred bucks more, it was worth it. YMMV, though.
  16. luke_ha
    luke_ha Stunt Coordinator
    Feb 11, 2004
    84
    its the one question that noone has the diffinitive answer on.
    honestly you are probably perfectly fine with what you have.
  17. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Aren't the Illuminati one of those secret cults?
  18. Robert_Dufresne
    Robert_Dufresne Stunt Coordinator
    Mar 30, 2002
    246
    JanH
    You must stop thinking analog . As long as a digital stream gets thru a cable unchanged, it doesn't matter what cable you use, cheap or expensive. There is no such thing as more detail or resolution. The stream is either transmitted or it is not.
    As long as your processor can decipher the 0's or 1's it doesn't care what cable you used.
    Could it be that you ear a difference because you cant face the fact that you just blew 100$.[​IMG]
  19. chris_everett
    chris_everett Second Unit
    Jul 20, 2003
    403
    The one argument I've heard for Coaxil over Fiber is that with fiber you have to go through another pair of A/D converters (converting the signal into pulses of light). IF the converters were poorly built, it MIGHT be more suseptable to problems. Given that coax is usually cheaper anyway, I've chosen to stick with it, and have a direct electrical connection. I should also add that I'm using a pretty cheap video cable for the interconnect, have had no problems, and see no reason to upgrade to something "exotic" IMHO, YMMV
  20. Bob McElfresh
    May 22, 1999
    5,182
    Well, there is 1 difference between optical & coaxial & a 'better' coaxial cables.
    Let's start with this question:
    If a signal is a voltage difference, where do the 2 voltages come from?
    With a coaxial cable, the shield/outer part of the RCA plugs connect the 0.00 volt reference from the reciever to all the box's. This means all the components 'share' the signal ground - they all become a part of it.
    Ever pump your own gas and see your hose jump/shake? Then notice someone else clicking their handle. You both have separate pumps, but what one guy does affects what happens on your hose.
    HT gear is the same way: all the electronics become a part of the 'signal' ground.
    I suspect this may be why some people have heard differences on high-accuracy systems when switching from optical to coaxial: the coaxial connection adds another device to the signal ground.
    A "better' coaxial cable - tigher RCA plugs => better ground connection.
