MyHD 120 card problems
Discussion in 'Computers' started by videobruce, Apr 4, 2004.
  1. videobruce
    videobruce Stunt Coordinator
    Sep 23, 2003
    143
    I hate just to use the word 'problems', but since it is more than one and I couldn't make a long story short, I used that term.
    I have the MyHD MDP120 card and daughterboard. I'm running 2k w/sp4 and a Sapphire 9100 video card. The monitor is a 19" Planar LCD with 1280x1024 native resolution.
    When I installed the latest beta driver/app (yes, I know it is a beta version, but with all the fixes I wanted to start there) the DVI signal died. I only had a VGA to the monitor. Now I have to start the app and fiddle around to get the DVI signal back.
    Next, I can't get the HD mode to work. I tried different settings with the resolution choices including native and tried different aspect ratios, but the HD mode is either distorted , grossly overscanned, or not there. I can stretch the overlay window to fill the desktop, but that shouldn't be the way it works.
    BTW, I do have that option of enabling flat panel support (or something like that) checked.
    Any ideas?
  2. Mike Fassler
    Mike Fassler Supporting Actor
    Jan 17, 2004
    523
    revert back to the other driver and see if the functions come back [​IMG]
