MY TV doesn't look that good with my DVD player
Discussion in 'Archived Threads 2001-2004' started by Babek, Jan 4, 2003.
  1. Babek
    Babek Stunt Coordinator
    Jan 1, 2003
    87
    hey,
    Please read the story carefully.
    I have: a 57hx81 Toshiba widescreen TV
    and a SD-3750 Toshiba progressive scan DVD player
    Now, my cousin has: a 50h82 Toshiba widescreen TV
    and some Denon 5-disc dvd player( no progressive scan)
    I have the better TV than him, and maybe a better dvd player too since mine is progressive scan and his isn't. Anyway, I went to his house and his screen looks fabulous. We watched starwars and it looked like it was HD or something even though there was no progressie scan. It was amazingly clear
    I go home and pop in star wars and I just don't get the same quality as his. Is it because his screen is 7 inches smaller? Or is it his dvd player that's better? Remember mine has progressive scan and his doesn't.
    I'm not saying mine isnt clear, mine is very clear, but just not as clear as my cousins was.
  2. Babek
    Jan 1, 2003
    87
    oh and both me and my cousin are using high-end component video cables.
  3. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,717
    463
    Have you calibrated your RPTV with Avia or Video Essential (as a minimum)?
  4. Babek
    Jan 1, 2003
    87
    I have no idea what you're talking about. All I need was plug the component cables into the tv and put progressive scan on, and fixed minor brightness/contrast levels and that's all.
  5. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    What Patrick is referring to are calibration disks that help you peoperly set up the video controls (sharpness, picture, colour, etc) to achieve the best results short of hiring a professional calibrator to tweak the TV to tip-top shape. The disks (AVIA, Video Essentials, and others) are avilable in many stores that sell DVD's.
  6. Babek
    Jan 1, 2003
    87
    anyone else know what i should do?
  7. Richard Travale
    Richard Travale Producer
    Feb 27, 2001
    3,425
    12
    The Island, Canada
    Rich Travale
    Neil and Patrick have hit it on the head. You really should go and get the V.E or Avia disc and properly set up your TV. Until then you are probably dealing with apples and oranges when trying to compare your set to anyone else.
    I mean, C'mon, you just spent $5000+ on a TV. The least you could do is spend $80 to get it looking as good as you can get it on your own.
    Of course the other option is to just sit tight until you have about a hundred hours of viewing and the hire an ISF tech to come and fully calibrate your set. This will cost you anywhere from $500 up but it will get your set looking as good as it is capable of.
    By the way, welcome to the forum.
  8. greg_t
    greg_t Screenwriter
    Jan 18, 2001
    1,650
    As was already stated, Avia/Video essentials is a must and then if you want to go all the way, get an professional ISF calibration.
  9. VicRuiz
    VicRuiz Second Unit
    May 21, 2000
    392
  10. BruceSpielbauer
    BruceSpielbauer Second Unit
    May 27, 2002
    275
  11. Hanson
    Hanson Producer
    Nov 1, 1998
    4,686
    144
    Hanson
    Why don't you get your cousin to come over your place and do what he did to his set to yours?
    Also, just a thought -- does anyone know if one set does 480p versus 540p upconversion?
    Hanson
  12. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Both units in question do 540P upconversion. The 81 does it worse than the 82.
    regards
  13. ManW_TheUncool
    ManW_TheUncool Producer
    Aug 18, 2001
    5,987
    36
    The BK
    ManW
    Besides what's already been mentioned, it might also be possible for the Toshiba progressive scan player to do worse linedoubling than the Toshiba 50H82's internal doubler w/ this Star Wars DVD.
    I don't mean to suggest anything, but if this DVD is really for the original Star Wars movie, not the prequels, then it definitely can present a problem for the player that it might not for the TV's doubler.
    Anyway, assuming it's one of the prequels, then the difference in upconversion between TVs could be the culprit among other things.
    _Man_
  14. Babek
    Jan 1, 2003
    87
    thanks guy for your help. I will order the AVIA disc soon.
    Anyway, I'm just wondering if buying a high end dvd player ,like my cousins denon, would make a difference to picture quality?
  15. Rich Chiavaroli
    Rich Chiavaroli Stunt Coordinator
    Sep 29, 2002
    90
    why not bring your cousins over and see if you think it's worth it.
  16. Todd Phillips
    Todd Phillips Second Unit
    Oct 15, 2000
    279
    Why don't you try his DVD player on your TV to see if it makes any difference?
    It's most likely the TV, though.
