My TiVo IR/lights seem busted: how do I fix/troubleshoot this?
Discussion in 'Archived Threads 2001-2004' started by Ernest Aguayo, Nov 20, 2002.
  1. Ernest Aguayo
    Ernest Aguayo Stunt Coordinator
    Apr 5, 2000
    105
    Hey there...
    My TiVo's two LED lights have gone out and the IR sensor seems to have broken today.
    The remote/batteries still work b/c I can still use it to turn on my TV and to change the volume.
    When I turn the TV on, I am at the mercy of whatever is on Live TV. I do see the TiVo continuing to change channels (and display the channel header) correctly at the top of the hour as it goes about recording shows on its to-do list. I just have no control of accessing TiVo Central to view shows, change any settings, or really doing ANYTHING with the remote.
    How do I fix this or further troubleshoot the problem? Can I just replace the IR/light assembly or something?
    Thanks for your help!!!
  2. Ernest Aguayo
    Apr 5, 2000
    105
    I should mention that I hacked this TiVo a while ago, so I don't have a warranty to fall back on...
    Thanks...
  3. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,296
    52
    9,110
    Mississippi
    Try Tivo Community. Someone there should be able to help.
    -Robert
  4. Ernest Aguayo
    Apr 5, 2000
    105
    thanks for the suggestion, robert.
    they suggested i reboot it and i just tried it and it worked.... strange. but i am not complaining... just so glad it worked!!!
