Kevin T
- Jul 12, 2001
i have a wicked hum in my system after a recent cable install. changing the coax cables did nothing nor did a cheater plug help. the hum is quite odd in that it is only comes through on the 6 channel input of my pre-pro. it's not the 6 channel cable either as i thoroughly checked that. what's odd about the hum is that if i connect a wire to the ground of my line conditioner and then touch the other end of the wire to the diplexer, the hum gets far my quiet though still present and noticeable. my only guess is it's a ground loop hum and i order a xantech ground breaker so hopefully that will help. anybody got any other ideas as to what it might be if it's not a ground loop? thanks.
kevin t
kevin t
