Ted Lee
- May 8, 2001
hi all -
i recently noticed that my system produces a low buzzing noise no matter what input i choose as long as something is connected to that input.
i hope that makes sense...
so, for example, my receiver does not buzz when i choose phono or video 3, since nothing is connected on the back. but every other input produces the buzz.
a couple of other things...
the buzz seems most prevalent when my volume knob is around the nine o-clock position. also, if the component is not powered on, then i don't think there is a buzz. it seems to happen only when i select the component and turn it on.
so, since it happens regardless of what input i select, it would seem logical that something is up with my receiver and not necessarily my wiring or inter-connects? i can't figure out what could be causing it.
i don't think it's my wiring...
i have all my power running down one side of the rack and all my interconnects running down the other. i also have everything plugged into a pretty decent kensington power-strip. i'm using rat-shack gold series & monster-cable for all my connections.
any ideas?
tia
any ideas?
tia
