My subwoofer will not turn on!
Discussion in 'Speakers & Subwoofers' started by RyanCai, Sep 11, 2004.
  1. RyanCai
    RyanCai Extra
    Mar 7, 2004
    24
    Hello everyone,
    Here's what happen, i was moving my receiver & the cable of the subwoofer got unplugged. I thought I turned both receiver & subwoofer off....i plugged the subwoofer cable back into the subwoofer & then a loud sound came on. Now my subwoofer will not power up. I'm assuming this is a blown subwoofer? Is there a way to fix this?
    thanks in advance.
  2. Kernel X
    Kernel X Extra
    Feb 26, 2004
    24
    You might have just blown the fuse in the back of the sub. There should be a screw-in fuse in the back of your sub, just replace the fuse with the same type. Make sure everything is unplugged before you begin. Hope that's all it is...good luck Ryan.
