Anthony_I
- Sep 9, 2003
Im not sure what it is but im wondering if someone could help me identify it.
It resembles the sound of air rushing out through a crack, but i cant seem to localize it, it sounds almost as if it is coming from the dust cap, but also like it could be air squeezing its way out from where the speaker is mounted to the box. Also it isnt doing it all the time, only when the speaker really gets moving. Like during "In Da Club" by 50 cent it makes this noise when the lowest bass in the song hits, but not any other time. and only when it is turned up past a certain level.
Is there anyway i can determine weather or not it is actually an air leak, or something wrong with my driver?
if i push the cone in, it doesnt make any scratching noises or anything, so im sort of lost.
The speaker is a Phoenix Gold Octane R12d.
any help is appreciated.
----EDIT----
Ive been doing some listening, and im 90% sure that it is not my driver, the sound seems to be coming from slightly below where it is mounted, and from the box itself. I also removed my amp, and to the best of my knowledge it isnt making that noise when the amp is out of it (IE with a big open hole in the back, and no real strain on the box. basically free air)
Still i need some way to figure out exactly what this noise is so i can correct it. Its so hard to figure out cause i cant seem to get an EXACT fix on where it is coming from.
----EDIT----
