My Sonosub design
Discussion in 'Archived Threads 2001-2004' started by Eduardo, Apr 18, 2002.
  1. Eduardo
    Eduardo Agent
    Apr 10, 2002
    47
    Hello Everyone,
    After 2 months of reading forums and personal web sites of how to build speakers/subwoofer, I have decided to build my first subwoofer. I have learned a lot from the people from this site and I would like you to review my design. My subwoofer will be a sonosub with a single port and powered by Adire AVA250. The sonotube was donated by Jim Robbins.
    Volume: 144L
    Driver: 12" Shiva
    Port(D): 5"
    Port(L): 26"
    Tuned: 18 Htz
    Sonotube(OD): 18"
    Sonotube(L): 40.2"
    Room Dimensions: 24.8' X 13.6
    Please let me know of any ideas or suggestions.
    Thanks in advance
  2. Eduardo
    Eduardo Agent
    Apr 10, 2002
    47
    Has my thread been closed or locked? Mods Please help
  3. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    No and No.
    The design looks pretty good on paper, so go forth and build you a sonosub!
  4. Andrew Low
    Andrew Low Extra
    Jul 27, 1999
    23
    Unless you have already found the 5" diameter pipe for your port, you might reconsider. I couldn't locate any easily in my area.
    I ended up using a 4" port and it is fine -- I've never had any port noise problems, but I listen to things at a reasonable level. You could always move to a 6" port [​IMG]
    Your very close with your design to the Shiva whitepaper EBS alignment (this is good).
    The best advice I got when designing my sub, I'll pass on to you: "Just go build it".
    www.quux.net/roo/diy/sonosub
    Roo
  5. Patrick Sun
    Jun 30, 1999
    38,749
    480
    9,110
    The 6" port would require about 40" of length, so that's out of the question.
    If you go with a 4" port, I would recommend the flared variety (A Precision Port is around $14 plus shipping at places like Parts Express).
  6. Eduardo
    Eduardo Agent
    Apr 10, 2002
    47
    Pat and Andrew,
    Thanks for the input and for having great websites. I use both of your sites as referencce.
    I was worried with the 4" port becuase of the airspeed in port. Checking ISD I will tuning the Sub to 17Htz this will keep the airspeed under 15 m/s.
    Port(D): 4"
    Port(L): 17.5"
    Tuned: 17.3 Htz
    Sonotube(OD): 18"
    Sonotube(L): 39"
    This project will be starting in the next 2 weeks.
  7. Eduardo
    Eduardo Agent
    Apr 10, 2002
    47
    I'm looking for advice for my Sonosub design (AGAIN). I have cut the endcaps, made the base, cut the port hole, bought the port(flared) and hardware except the driver.
    Port(D): 4"
    Port(L): 17.5"
    Tuned: 16.7 Htz
    Sonotube(ID): 18"
    Sonotube(L): 39"
    According to to my calculation with the port and driver installed I should have an internal volume of 155 L. Is this volume OK?
  8. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Yep, looks right to me, but LspCAD gives me 17.1hz or 17.5hz depending on if I used 17.5" to be the length that includes the flares or doesn't.
