JimmyK
- Jun 21, 2002
- Jim
I've been working on reintegrating my SVS 46-16PC+ with my main L&R speakers (ADS L1290's) since purchasing an Anthem AVM 20 v2.xx.
The lowpass crossover on the AVM20 is set to 80hz and the highpass is set to 50hz. Setting both crossovers to 80hz resulted in a deep hole centered at 80hz, so I lowered the high pass filter to minimize this effect. I guess I could have raised the low pass filter instead, but I don't want to end up with easily localized frequencies coming from the sub.
All speakers (including the sub) are set to read 75db on my Radio Shack digital spl meter. I am using an Audio Control 10 band graphic EQ on the L&R speakers only (no EQ on the sub) to tame a nasty bump between 85hz-125hz. Sub is located in the corner next to my L speaker.
Measurements were taken using sine waves at fequencies 1/6 octave apart. If I measure frequencies in between, the response gets a little more ragged looking, but I expect this is normal. I ran the signals in stereo mode with both sub and L&R speakers on, since this is how I do most critical listening.
Setting the meter to it's lowest setting revealed no response from background noise, so I'm pretty sure my measurements are not poluted.
I am unable to post a picture of the resulting graph, so here are the numbers I came up with. The numbers include the correction values for the Radio Shack spl meter.
16Hz....70.0db
18......70.2
20......70.5
22......71.0
25......72.0
28......73.5
31.5....74.0
36......74.0
40......73.5
45......71.0
50......70.5
56......71.0
63......69.5
71......71.0
80......67.5
89......71.0
100.....69.0
111.....66.0
125.....58.5
142.5...61.0
160.....59.5
From 160 and up, the response stays around 61db until about 300hz or so, then rises to about 64db the rest of the way up.
So my questions are:
1. Does it appear my method of measurement is sound?
2. Does this represent a good response? (It sounds good, but I always wonder if it could be better.
I'm sure many of you here know what that's like!)
3. What would you change, if anything?
Thanks in advance for your input/advice!
JimmyK
16Hz....70.0db
18......70.2
20......70.5
22......71.0
25......72.0
28......73.5
31.5....74.0
36......74.0
40......73.5
45......71.0
50......70.5
56......71.0
63......69.5
71......71.0
80......67.5
89......71.0
100.....69.0
111.....66.0
125.....58.5
142.5...61.0
160.....59.5
JimmyK
