For whatever reason, my PS3/40GB seems to have slowed down a whole lot w/ loading certain titles (both for Blu-ray and DVD, but more so w/ DVD) and sometimes even gets stucked for so long (like a few minutes) that I give up and reboot the thing. It used to be quite fast, but now tends to be sluggish at loading discs.
And on occasion, it would also get stuck trying to shutdown (ie. go to standby mode) and require a hard power-off w/ the hard switch. I've also had a couple times where it just locked up when simply navigating the menus (even just from a fresh startup). And there were a couple times when it lost certain settings like the display and audio settings (but not the network settings, etc) and then booted up at 480i, etc.
Anyone else running into these problems?
It seems to be behaving a bit like when a PC installed something and got flaky *or* there was some system crash that left it a bit unstable. I'm guessing that's likely what it is -- maybe something went wrong during a shutdown cycle or something. I'm also wondering if it's not something to do w/ the WiFi networking and how it likes to download some small pieces of data (like promo/advertising info) off the internet, eg. from the PS website. No, I haven't downloaded any software updates since when I first bought the PS3 nearly 4 months ago -- still running v2.1(?) from December -- so that's probably not the problem. No, I also haven't used the other media hub features and only used the web browser a handful times earlier on, but not recently, so I doubt there's any hard drive fragmentation issue or disk space issue or the like.
Any ideas? I'm thinking maybe I should just download the latest update for Profile 2.0 and DTS-HD/MA, etc. even though I don't really need any of that right now. Maybe that will fix the problem just by going to a freshly updated system state.
Thanks for any help you can offer...
_Man_
_Man_
