My pointer hangs up?
Discussion in 'Computers' started by Wes, Apr 19, 2005.
  1. Wes
    Wes Screenwriter
    Sep 30, 1997
    1,190
    Utah USA
    Wes Peterson
    This is driving me nuts, My XP PC is working great in all other aspects but as I move the mouse the pointer starts moving then stops for a few seconds then frees up. My pc is a e-machine AMD 2700 with 512 SDDR ram and 64mb video.
    Any ideas as to what is causing this?
    Wes
  2. Ed Moxley
    Ed Moxley Cinematographer
    May 25, 2003
    2,701
    Eastern NC
    Ed
    Clean your mouse!
    Open the bottom. The rollers that the ball rolls on collect dust and dirt. Sharp pointed tweezers are ideal, but a small bladed knife will work. Just be careful. You can use a Q-tip and alcohol to wet and loosen the dirt. Once cleaned, it should work like a brand new one!
    Good luck! [​IMG]
    BTW.........
    I bought an optical mouse, for this very reason..........
  3. Wes
    Wes Screenwriter
    Sep 30, 1997
    1,190
    Utah USA
    Wes Peterson
    Nope it is an optical mouse (no ball)! I should have mentioned that!
    Wes
  4. Ed Moxley
    May 25, 2003
    2,701
    Eastern NC
    Ed
    Oh, sorry............
    Have you tried another mouse?
  5. DaveF
    DaveF Moderator
    Mar 4, 2001
    17,973
    1,543
    One Loudoun, Ashburn, VA
    David Fischer
    Do other things stutter simultaneously? If you're playing MP3s, does the music halter at the same time as the mouse? If you're typing, does the text stop briefly during the hiccup?
    It might not be a mouse problem, but could be something causing your system to briefly pause. My older PC, running Win XP does this frequently. Some process randomly grabs the 100% of the CPU process, causing all other tasks to freeze for a half second.
  6. Wes
    Wes Screenwriter
    Sep 30, 1997
    1,190
    Utah USA
    Wes Peterson
    Dave that’s what it seems like but no other things hang up at all, just the mouse. And it's not all the time just occasionally but enough to drive me nuts!
    I have not tried another mouse perhaps I will do that!
    Wes
  7. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    I had the same problem with a Benq wireless optical mouse, I ended up figuring it was a driver problem(Benq install for the extra button), and never used it again
    Mind you the Benq Keyboard is awesome..
    "My pointer hangs up" ......HAHA but only when I wake up!
    Brent
