JonZ
- Dec 28, 1998
Bill,
IMHO dumbells are safer than barbells. If you cant bring the weight up, you simply drop it. If you fail on barbells, the weight can fall on you.
With barbells, you know when u wont be able to do more so youll stop before absolute failure becuase u have to have the strength to lift the weight and put it back - the routine I showed u guys ONLY works if you go to absolute failure. I would suggest sticking with dumbells.
Do u go to the gym with someone who can spot you?
