My PB 12 has gone crazy! (1 Viewer)
KyleRoussel
I was upstairs eating when all of a sudden my house started rumbling with this awful noise. When I got into my room I found that my sub was firing and rattling for no reason. What's going on??
KyleRoussel
Damn, that blows. It was barely a year old. Did JBL ever fix the problem or have they been replacing it with more faulty amps?
John Garcia
NorCal
Check with JBL, I've seen some people say they've gotten them replaced under warranty, since this is a defect. What you described is exactly what happened to a friend of mine. I think they have solved the problem, but many of the bad amps are still out there.
HienD
I was thinking of buying a pb10. It's sounded pretty tight and punchy without the boom. The only thing that stopped me were the reviews stating how bad the amps were. Good thing I didn't pick one up.
KyleRoussel
I was happy with it until it went to visit the crapper. I got it from my bro who works for a JBL distributor so I'll get it fixed for no charge (I hope) and hopefully they'll replace it with one of the fixed amps.
David Lawson
Cincinnati, OH
David Lawson
Yikes...my landlord would have a fit if that happened while I wasn't home. Perhaps I should turn off my PB10 when I'm not using it, just in case.
KYLE I just bought one have they fixed the problems on the new ones or are they lemons.I read your post after i ordered it there is a few more stories just like yours out there.I think iam stuck with it inless i eat the shipping cost.But you did like it did it sound better than the saw-40?
Similar Threads
RobRWA123
