My new TIVO is noisy!
Discussion in 'Playback Devices' started by gene c, Feb 21, 2004.
  1. gene c
    gene c Producer
    Aug 5, 2003
    5,850
    51
    9,110
    Bay area, Ca
    Gene
    My DirecTV Hughes Tivo is really loud to me. Is this normal? Sounds like the hard drive is always spinning. This thing is always on too. Is this going to add allot to my electric bill? I think I'll be happy with it over all, but I do miss some of the features my old Sony SAT-B2 had. BTW, for those of you who know about my old Sony shorting out a couple of weeks ago, I plugged it in yesterday and for some reason it works again. Go figure. Gene
  2. Tim Holyoke
    Tim Holyoke Second Unit
    Nov 6, 2002
    268
    Gene - My new DirecTivo doesn't make much noise at all. And yes, they are always on, it won't use much electricity. Not sure what the problem could be w/the noise. Like Robert_J has stated here many times, all DirecTivos are made in the same plant, they just look different on the outside, but mine is a Samsung, I still don't think that would make a difference.
  3. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    At first I thought you were talking about the fan noise--they can be noisy in that way, but not the kind of noise you are describing.
    Incidently, my replay TV doesn't make a hard drive kind of noise like my computer sometimes does. You should definitely exchange it.
    DJ
  4. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,296
    52
    9,110
    Mississippi
    Someone figured it up at the Tivo Community. It uses less electricity than a 60 watt light bulb. It was no more than a couple of dollars a year in electricity.
    There are a few things you can do. You can swap the fan for a quiter one. A lot of computer suppliers have silent or almost silent fans. Second you can get a different hard drive. WD or Maxtor (I can't remember which) have some type of acoustical management software you can turn on. It makes the drive alomost silent. A bonus is that you could upgrade to a larger drive at the same time. Finally, I read where one guy put something like Dynamat on the inside of his case to dampen sound. This sounds like over-kill to me.
    -Robert
  5. gene c
    gene c Producer
    Aug 5, 2003
    5,850
    51
    9,110
    Bay area, Ca
    Gene
    Thanks for the info guy's. Yes "loud" is relative. This is just louder than I expected. I now believe it's the fan and not the drive I'm hearing. Gonna go to BB and have them plug in one of their's for comparison. Also where I have mine located echo's the sound. And I do most of my watching in this particular room late at night with low volume. All these things add up to more noise from the unit than I'd like. Installing a quieter fan is a good thought. That, along with a few other changes like placing it in a less "echoey(?)" location, may help reduce the noise level. BTW, I'd say it's about half as loud as the fan on my PC. O.K. for computing but not for viewing. Again, thanks for the help. Gene
  6. Alf S
    Alf S Cinematographer
    Apr 23, 2000
    2,973
    508
    4,110
    Alfer
    [​IMG]
    I don't know what BB you go to but the one I go to would be the last place I'd want to try to hear the tiny difference in sound from a Directivo in their store...[​IMG]
    If it's like our BB, it's blasting some kind of crappy rap/gansta music morning, noon, and night turned up to "11".
    If I were you, I'd either ask for an exchange or live with the fact that the DTivo is indeed a bit noisier than your everyday DTV receiver. [​IMG]
    Alfer
  7. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    yeah, mine is a little noisy too. if it's totally quiet in the living room i can hear it. plus, if i have my music server on .... [​IMG]
    anyway, it's not that big of a deal and the bennies definitely outweigh any gripes i may have.
    i seriously doubt bb will do anything for you other then exchange it. as already stated, that store is noisy as heck....drives me crazy....and i work there!
  8. andrew markworthy
    Sep 30, 1999
    4,762
    12
    I have a Sky+ box (a similar sort of HD recorder). It too makes a noise: the nearest equivalent sound I can think of is a fridge when it suddenly kicks into that weird high pitched buzzing noise that all fridges seem to go into every few hours (why?). I find it mildly annoying at times, but that's about it, and certainly it's no more irritating than the sound of a VHS recorder wheezing along.
