Dustin B
- Mar 10, 2001
I completed my Tempest sonosub several months ago, and it was just under a month ago that it and I went back to school. Problem is, the house was built in the mid 50s and right beside where the sub goes are mid 50s windows. Wooden framed single paned windows that open by sliding in wooden grooves. Then there is also a single pain storm window on the outside of this. As you've probably guessed the problem is the sub really makes these windows rattle. So how to solve the problem.
First attempt. String a wire across the window, twist it tight, and place some stiff foam between the window and wire. Took some of the rattles away during music with milder bass. But movies and music with heavier bass still rattled the damn things.
Second attempt. Bought 4 bike tire inner tubes (there were 4 panes to deal with). 12.5" tire diameter by 2.25" tube diameter. Folded them and taped them up so they would expand properly, then placed them between the storm window and the window and pumped them up until they were exerting pressure on both pains. Problem more or less solved. No more rattles. Only the sounds created by really big bass that shakes the whole house. Which saddly I can't do anything about.
Tis sweet not having WAF to deal with and owning the place you live in while going to school
Dustin
[email protected]
My Adire Tempest Sonosub
[Edited last by Dustin B on September 28, 2001 at 06:39 PM]
Dustin
[email protected]
