My new DIY A/V rack
Discussion in 'Home Theater Projects' started by Ron-P, Jun 22, 2006.
  1. Ron-P
    Ron-P Producer
    Jul 25, 2000
    6,284
    5
    Ron
    Due to vibration issues with my gear inside the HT I finally got it all out. Over the past week I built this on the exterior side of the HT with all materials I had at home for other projects, all the parts did come from Home Depot. Here are the pics from start to finish.
    I had these racks from left over from when I first built my HT. Each shelf can support 250lbs. It's screwed into the studs of the HT with 4" deck screws. I also installed a 20amp dedicated line off the main house breaker for power.
    [​IMG]
    The shelving is decoupled from the HT using a neoprene washer and a flat cut washer. This helps dramatically reduce vibrations.
    [​IMG]
    I started to install the shelf brackets and shelving. I also installed 3 1" diameter holes to the inside of the HT for all the cabling and wires. I used schedule 40 PVC.
    [​IMG]
    Each shelf is also decoupled from the bracket using flat cut washers.
    [​IMG]
    A rough layout of the interior.
    [​IMG]
    The finished product.
    [​IMG]
    Everything in it's place. I am using the leapfrog RF system to control the geare from inside the HT.
    [​IMG]
    An access door in the back provides all the room I need to access all the connections.
    [​IMG]
    Needless to say that this thing is so well isolated from the HT that vibrations and cooling is no longer an issue.
  2. Don.l
    Don.l Stunt Coordinator
    Apr 9, 2005
    120
    Sweet! I like the PVC pipes for the cables. Very good idea. Leapfrog RF? Never heard of it. Does it work well? Is it expensive?
    Don
  3. Ron-P
    Ron-P Producer
    Jul 25, 2000
    6,284
    5
    Ron
    Thanks Don. Yes, the Leapfrog works great and right now at Amazon you can land it for $25.
  4. Brian Osborne
    Brian Osborne Stunt Coordinator
    Sep 2, 2005
    215
    I second the leapfrog. i use it too, actually I use 2 of em, one for the HTR and one for the living room upstairs. both work without a hitch pointing to the same A/V rack
  5. TonyD
    TonyD Who do we think I am?
    Dec 1, 1999
    17,296
    473
    Disney World and Universal Florida
    Tony D.
    inside the box doesnt need circulation?
    looks like it could get hot i there if it is closed while in service.
    link to the leapfrog item?
