Matt Dolejsi
- May 13, 2003
Hi, I'm just looking for any advice having to do with my current project...
I bought sixteen 4" drivers (couple bucks a piece) to put in a line array configuration that i'll probably end up using as my center channel if it all works out ok. Fs of about 105 which is not too too bad, I can get the over all Q very close to .707 be it that it is a little higher, but with some EQ and stuffing it should be fine i think.
Of course there's only 1mm xmax but frequency response is quite extended and having 201 in^2 of cone area should help with some bass output.
Any advice, thumbs up, or criticism is welcome...
