My latest 3D Project (Please give your honest opinion)
Discussion in 'Archived Threads 2001-2004' started by Brett DiMichele, Apr 6, 2002.
  1. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Hey Folks!
    I decided to scrap the other Pentium 4 3D Model I was working
    on due to the glaring inacuracies that I could not easily
    fix.
    Therfore I decided it would be best if I started again from
    scratch. This time I worked closely with many in depth images
    of the real Pentium 4 Processors and I even found an image
    of a P4 with it's IHS (Integrated Heat Spreader) removed
    exposing the core. This was great because I even took the
    time to add the core under the IHS. I especialy took my time
    counting the rows and columns of Socket Pins on the real
    deal (478 Pins) and they are all present and accounted for
    on the 3D Model.
    I still have to tweak the materials for the PC Board somewhat
    and I also need to finish the IHS because it is not 100%
    complete yet. Then I need to determine how I want to render
    this image for the "final" render to give it the reality
    look I am going for.
    If you are wondering there are roughly 60 thousand polygons
    in this wireframe! Yeah I know thats "nuttin" by comparison
    to some complex machine models I have seen with 500K Poly's
    but for a CPU I'd say that's a ton! [​IMG]
    Okay here ya go.. Be brutaly honest!
    [​IMG]
  2. Brett DiMichele
    Sep 30, 2001
    3,181
    I tell ya.. This stuff is more adicting than a crack laced
    joint rolled in LSD treated papers! [​IMG]
    [​IMG]
  3. David_Stein
    David_Stein Second Unit
    Feb 13, 2002
    422
    it looks _good_
  4. Geno
    Geno Supporting Actor
    Oct 1, 2001
    637
    smoking LSD doesnt do anything to you
    Also, is there anything else you can render? Ive seen your chips and they look great, but this is HTF, I was hoping to see some cool renderings of a cool HTF. I personally work with 3d max and and I am trying to build my apartment in 3d.
    If I had a place to post my pics, I would.
