My JVC XV-SA75GD is Pan & Scaning my Widescreen DVD's!
Discussion in 'Archived Threads 2001-2004' started by Ash Williams, Mar 1, 2002.
  1. Ash Williams
    Ash Williams Second Unit
    Oct 16, 2000
    256
    I have a JVC XV-SA75GD DVD player connected to a 4x3 27" Sony Trinitron TV via S-Video. When a watch any widescreen material, about [​IMG] an inch of video is cut off on each side of the image. I know this because when using the zoom function to zoom out, I see more of the image. Does anyone know how to fix this?
  2. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    I would think that's a function of your TV's overscan of the display.
    I think Avia's DVD's Video calibration will show you exactly how much overscan your TV has.
  3. Ash Williams
    Oct 16, 2000
    256
    Well the thing that bugs me is that my old player didn't do it. My old player was a $200 RCA that I bought in 99', the model number evades me. I have Video Essentials but I guess I will have to pick up a copy of Avia too.
  4. efren
    efren Auditioning
    Feb 21, 2002
    12
    I think you can adjust that by going into the setup menu of the player. You can either select 4:3 normal, 4:3pan/scan, 16:9 auto, 16:9 normal. I forgot if it's Preference 1 or Preference 2 tab...hope this helps.
  5. Ash Williams
    Oct 16, 2000
    256
    Efren,
    I tried that already. I'm guessing it's my TV. Thanks for your input though.
  6. Andrew_Ballew
    Andrew_Ballew Second Unit
    Feb 21, 2002
    294
    Sounds like TV overscan to me as well.
    cheers
    Andrew Ballew
  7. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    >>my old player didn't do it...
    I would not be surprised if some players did not fit the picture material accurately onto the scan lines it sent to the TV. It could even be intentional, the player leaves a tiny amount of blank space (made black) at the far ends of the scan lines to second guess the overscan on the TV. Although intentionally compensating for overscan in the vertical direction is much more difficult because it requires scaling, fitting the 480 rows of pixels onto fewer scan lines.
    Video hints:
