My Internet Explorer and Mozilla Fonts
Discussion in 'Computers' started by Sam Davatchi, Jan 16, 2005.
  1. Sam Davatchi
    Sam Davatchi Producer
    Sep 15, 1999
    3,150
    I think I’m going insane, I see all the topics in italics! Both in Internet Explorer and Mozilla, my fonts are in italic and they were not like this before. Where can I solve this font issue? I didn’t find anything in the Internet Options. Thanks.
  2. Harold Southard
    Harold Southard Stunt Coordinator
    Dec 31, 2003
    138
    In IE go VIEW>Encoding. You should be able to fix it there.
    In FireFox is the same.
  3. Sam Davatchi
    Sep 15, 1999
    3,150
    No unfortunately that doesn't work!
  4. Sam Davatchi
    Sep 15, 1999
    3,150
    Now I'm really going insane. I just posted this question on another forum and suddenly my fonts went back to normal!
  5. DaveNel
    DaveNel Second Unit
    Oct 13, 2004
    447
    Hello
    go to start menu, settings, control panel .. open control panel, click add remove programs, go down the list to ( Microsoft internet explorer, click to remove it. It will ask you then if you want to:
    1 Add a Component
    2 Repair internet explorer
    3 Restore the previous windows configuration
    click (2) it will repair it, Then reboot.. That should repair your problem..
    Now if you cant find it there, go to Program files, internet explorer. Then click on ie6setup.exe if you are using IE6
