My Icons Disappeared!! How to restore?
Discussion in 'Computers' started by Scooter, Mar 7, 2005.
  1. Scooter
    Scooter Screenwriter
    Sep 3, 1998
    1,505
    10
    DFW Area Texas
    Scooter
    When I did an XP SP2 upgrade some of my icons changed or disappeared, notably the disc icon for an ISO file. How do I get these back?
    TIA
  2. Scooter
    Sep 3, 1998
    1,505
    10
    DFW Area Texas
    Scooter
    B U M P
    Someone, anyone have a solution???
    TIA
  3. Gerald LaFrance
    Gerald LaFrance Supporting Actor
    May 28, 2002
    510
    Earth
    Gerald LaFrance
    I had a similar problem my Desktop Icons always changed or went blank, It turned out Windows Media Player 9 was the cause of it, I had to close WMP 9 then the Icons refreshed.
    I fixed the problem when I went to WMP 10.
    You could also try Tweak UI for XP it is found here:
    http://www.microsoft.com/windowsxp/d...powertoys.mspx
    to fix click Logon then Repair at the bottom left when you run Tweak UI, you will be able to repair your Icons.
    Hope that Helped you!!
  4. Scooter
    Sep 3, 1998
    1,505
    10
    DFW Area Texas
    Scooter
    Nope..didn't work..but I appreciate your effort. All it did was re-arrange my desktop.
  5. Parker Clack
    Jun 30, 1997
    12,220
    75
    9,110
    Kansas City, MO
    Parker
    Scoot:
    It sounds to me like they are gone (that is removed) and you are going to have to create shortcuts for them yourself.
    Parker
  6. LaMarcus
    LaMarcus Screenwriter
    Mar 7, 2002
    1,619
    It sounds like he may have clicked the "you have unused icons on your desktop, would you like windows to remove them?" option.
  7. LaMarcus
    Mar 7, 2002
    1,619
    Try this out. Or go to help and support on your pc, and search for "restore shortcuts", make sure you click the Microsot Knowledge base bar at the bottom of the search results window. Good luck.
    APPLIES TO
    • Microsoft Windows XP Professional Edition
    • Microsoft Windows XP Home Edition
  8. Joachim Roperos
    Joachim Roperos Stunt Coordinator
    Aug 6, 1999
    62
    Or try to reinstall your graphic card's driver.
  9. Scooter
    Sep 3, 1998
    1,505
    10
    DFW Area Texas
    Scooter
    Ok....
    LaMarcus: Although the direction you sent me in did not fix it, it gave me insight as to how to do it!!! basically put me on the right track..thanks!!!
    Never EVER clicked the Delete Icons thingie. What happened is I clicked the file, and somehow got to where I could pick an icon for it and fixed it. Dunno exactly how, but it worked! Thanks to all for input.
  10. LaMarcus
    Mar 7, 2002
    1,619
    No problem bud. I'm glad you worked it out.
