My Ice Maker Stopped Making Ice
Discussion in 'After Hours Lounge (Off Topic)' started by Alex S, Jul 7, 2003.
  1. Alex S
    Alex S Second Unit
    Feb 21, 2000
    477
    We have a farily new refridgerator (18 months) that suddenly stopped making ice.
    The water from the door still works but the ice stopped.
    The trays are empty.
    Anyone have any suggestions on what I can check ?
    Thanks.
  2. Dave Morton
    Dave Morton Supporting Actor
    Oct 19, 2000
    753
    Dave
    I had something similar happen to me. I checked the top of the ice tray and found that a piece was stuck on top. For some reason, this caused it to stop. It wasn't much ice. So I just cleared out the ice on top and it started making ice again.
    Hope this helps.
  3. Alex S
    Alex S Second Unit
    Feb 21, 2000
    477
    Dave,
    Thanks for the reply.
    That's the 1st thing I checked because that happens a lot with mine. I didn't see any ice peices anywhere.
  4. Jay H
    Jay H Producer
    Mar 22, 1999
    5,654
    32
    Pittsfield, MA
    Jay
    Maybe there's a pack of Silica stuck at the top [​IMG]
    See the (in)famous Silica thread
    Jay
  5. Marc S Kessler
    Marc S Kessler Stunt Coordinator
    May 8, 2001
    186
    Check your water line. Maybe the filter is clogged.
  6. Alex S
    Alex S Second Unit
    Feb 21, 2000
    477
    Marc,
    But I'm getting water from the water dispenser on the freezer door. Wouldn't that not work as well ?
  7. Dave Morton
    Oct 19, 2000
    753
    Dave
    yeah, the water should be coming into the fridge by only one source. The only thing that could happen with the water line is that it is blocked when the line splits inside the unit.
    You may have to call a repair person for this one. I hate to say that!
  8. Jay H
    Jay H Producer
    Mar 22, 1999
    5,654
    32
    Pittsfield, MA
    Jay
    Have you looked for a fuse (that would only control the ice cube maker motor)?
    Jay
  9. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    my frig has a detachable ice bucket that locks into place. if it is not locked in place, no ice.
    took us a while to figure it out
  10. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    the little metal arm is in the down position, right? :b
  11. Alex S
    Alex S Second Unit
    Feb 21, 2000
    477
    Philip,
    There is no metal arm. [​IMG]
    It's a pretty new fridge with the ice bucket on the door.
    I'll check to make sure it's locked in but I'm pretty sure that was the 1st thing I checked.
  12. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    ah, I tried [​IMG]
    I guess those are a thing of the past these days.
  13. JoelC
    JoelC Stunt Coordinator
    Dec 28, 1999
    75
    Just had repairman over to the house for our Sear refridgerator with the same problem. Turns out the water comes in via a single tube and once inside the fridge it splits into two (one for the ice maker and one for the water dispenser). The ice maker line froze. He is going to replace it with a new line that has a heater in it to keep the line from freezing again. This could be your problem as it sounds the same as mine. Good luck[​IMG]
  14. Alex S
    Alex S Second Unit
    Feb 21, 2000
    477
    Thanks Joel.
    I just purchased a new contract for a year from Sears for this problem.
    I'll let you know the problem once they fix it.
