MY HT any thoughts? (1 Viewer)
AndyTod
Grip
I am putting in a HT area in my basement. Currently the basement is unfinished. The area is 12' by 24'. The room will have only two doors and no windows. I am looking at using the following equip:
Yam LPX510 projector
SNDQ100WFHWX Firehawk screen
Denon AVR3805 receiver
sapphire: ST3B front
SCBK center
polk TC601 surrounds and rear
Denon DVD DVD1910
Martin Logan 2X Dynamo subwoofers
Pronto TSU7000 remote
I like anyones thoughts on this setup. I am buying this all from Hi-Fi buys. They are performing all the install for me. Thanks
Mathew Shelby
Can you modify the dimensions at all? It is not good to have dimensions that are multiples of each other=bad sound
AndyTod
Grip
I can not changes the layout of the room much. After the room is finished the dimensions will be more like 11.5 by 23. If I go with Polk fronts and center channels can you recommend the models that fit into the range of 1200-1400 per pair for the fronts and 300-400 for the center?
Thanks for the advice
CodeineD1
