My GC is ticking me off!
Discussion in 'Archived Threads 2001-2004' started by Cameron Jensen, Nov 22, 2001.
  1. Cameron Jensen
    Cameron Jensen Auditioning
    Mar 10, 2000
    4
    Played it 1 day and the controller died. Glad I bought a spare so I can at least play but some of the two player goodness that I was planning for today is hosed.
    If your wondering what broke: The analog stick quit working normally. It always goes left or down no matter what you do to it. It was the unit that came with my GC. Now I have to figure out how I can get EB to swap it out.
    Cameron
  2. Mike Johnston
    Mike Johnston Auditioning
    Feb 11, 2000
    5
    Did you try resetting the controller? If you press X, Y, and Start at the same time, the controller is reset and the sticks become normal.
  3. Jeffrey Forner
    Jeffrey Forner Screenwriter
    Jun 19, 1999
    1,117
    Mike's right. It sounds as if the controller's neutral position got screwed up. Do what he says that should fix the problem.
    And just so you know, when you turn on your Gamecube, make sure that the control sticks are all at their neutral position in the center. If you have it pushed in another direction, the system will set that position as neutral and your controls will be screwed up.
  4. Rob Speicher
    Rob Speicher Supporting Actor
    Nov 24, 2000
    935
    I remember that problem happening with the N64 controllers, too. What Mike suggested should take care of it.
  5. Iain Lambert
    Iain Lambert Screenwriter
    Jun 7, 1999
    1,345
    I have to say that I think everyone has nailed it. The Dreamcast does the same thing with recalibrating its analogue controller, as well.
  6. Joe michaels
    Joe michaels Second Unit
    Mar 6, 1999
    282
    When you turn on any system with analog sticks you have to be sure they aren't pushed in any direction. If they are upside down on the floor this can cause a proble. Sometimes though, you get a lame stick that kinda moves into one direction which is not good.
  7. Morgan Jolley
    Morgan Jolley Lead Actor
    Oct 16, 2000
    8,888
    132
    9,110
    I think this is true for all consoles with analog stick controllers. PSX, PS2, N64, DC, GCN, and probably XB.
  8. Cameron Jensen
    Mar 10, 2000
    4
    Well guys it didn't work. The controller is defective. It will only go right. Not up down or left. [​IMG]
    Going through warranty service is such a pain. I will probably just bite the bullet and buy a new one, but this does really suck.
    Cameron
  9. Rusty Ray
    Rusty Ray Second Unit
    Jun 26, 1999
    273
    then i would return the defective one in the package of the new one you got... faster than service.
  10. Cameron Jensen
    Mar 10, 2000
    4
    I may just do that!
    Cameron
  11. Cameron Jensen
    Mar 10, 2000
    4
    OK I did it. Success. I now have 3 working controllers. [​IMG]
    Cameron
  12. Matt Wooten
    Matt Wooten Second Unit
    Aug 8, 2001
    355
    [​IMG]
  13. Andrew s wells
    Andrew s wells Second Unit
    Nov 20, 2001
    449
    [​IMG] [​IMG]
  14. Kelley_B
    Kelley_B Cinematographer
    Feb 27, 2001
    2,324
    I went to five stores yesterday looking for another controller for my 'cube so I could play some multiplaya Super Monkey Ball, hell I can't find even a generic controller.
  15. Morgan Jolley
    Oct 16, 2000
    8,888
    132
    9,110
    I have the controller it came with, a third party one, and I might have a third regular controller (its a long story).
