Steven M Dill
- Jun 15, 2000
Ahh four long weeks of sanding, priming, sanding, finshing, sanding, finshing, sanding, and finally finishing paid off Same design as Joseph Howard's except I wanted the elusive hi gloss black finish. I think it was worth the effort. Pictures linked because of the large size.
Primered
I used kilz primer/sealer. Nasty stuff but good for MDF.
Finishing the shelves
Note these are dry.
Finished
Stocked with my modest equipment
Also note my place normally isn't this messy :b I'me in the process of moving stuff around cause the flexy is so big.
Primered
Note these are dry.
Finished
