Ali_Techra
- Jan 28, 2003
Hi all, new to the forum.
Anywho, I've checked the "Primer" and did some searching but could not find the answer to my question.
I currently have 2 Definitive Technologies BP2000TLs that have a 15" powered sub in each. Unfortunatly, my Onkyo 777 has only one sub (LFE) output. I've used a "Y" splitter on it now and it works fine.
I plan to eventually add some Tactile Transducers to my system (and perhaps more subs ) and I'm wondering if there is a limit on how many times you can split the subwoofer RCA output?
In car audio they have ratings of the voltage of the pre-outs (ie:4 volts), but I was unable to find such a rating for home theater receivers and was wondering if there is a point of splitting where it will pull too much signal and take away from the other subs?
Thanks!
Thanks!
