Other than the finish, it is complete. I was able to wire it up yesterday for about 10 minutes and spin a few disks. The bass is very tight and fast and extremely powerful. My shirt sleeves were vibrating. The crossover is set at 40Hz and the amp at 1/3. At 1/2 the bass is way to powerful and my guts vibrate.
It is a 177L sealed enclosure with .75 MDF end caps inside with .75 plywood caps. I wanted plywood as I plan on using black stain for a matching woodgrain look to my Polks. I used two .50 all-thread rods inside locking the end caps together. I stuffed its guts with roughtly 60oz of poly-fill. I plan to add more and see what effects that might have.
All-n-all, I am very impressed with my first sonosub.
Thanks to all who helped me so much.
Peace Out~
Peace Out~
