my first DIY speaker. I need help getting started.
Discussion in 'Archived Threads 2001-2004' started by Paul Seyfarth, Feb 21, 2002.
  1. Paul Seyfarth
    Paul Seyfarth Stunt Coordinator
    Jul 7, 2001
    133
    I am looking to put together my first DIY speaker( not a kit ). I am going to start with a cheap bookshelf speaker, with a simple crossover. I am looking to spend under $150 for the pair. After doing that I can do something with a more complex crossover, and better drivers.
    Edit: any suggestions on speakers, or how to chose speakers. And where I can get information on building a crossover.
  2. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,296
    53
    9,110
    Mississippi
    Try Wayne's site. Read through the Speakerbuilding Articles. That should keep you busy for a few days.
    -Robert
  3. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
  4. Jon Torres
    Jon Torres Second Unit
    Dec 30, 2001
    288
    I would look at one of adire's free designs. I built the pop speaker and it sounds great. I'm now moving onto the grandpop. I think you should put together a kit before you start designing one.
    http://www.adireaudio.com/free_designs.htm
  5. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    I second Jon's advice. You could enjoy building a kit while reading up on design.
  6. John E Janowitz
    John E Janowitz Second Unit
    Oct 30, 2000
    445
    Hi Paul, You may want to check this out. http://www.stryke.com/S1.html This is a kit designed by Steve Sedmak around our inexpensive drivers, and closeout parts from Madisound. It is a tower speaker, but you can use the same crossover and just change the enclosure to be a bookshelf. Use the same depth and width, but make the enclosure only 18" tall and seal it.
    Driver quality IMO, and in most others as well, is much better than that of the Pop, and the other free designs.
