Rob Formica
- Feb 20, 2003
Ummm... but if i recall correctly, you can get a "NON-logorithmic" graph of the frequency response between 20 and 200hz using the low frequency add on in a resolution greater than 1Hz. It'll be more than enough to set up your EQ. It is covered in the demo room as well as on TAG (?) room eq web site. Perhaps someone could post you the link for the latter on as I don't have it handy...
No doubt that the learning curve is steep... perhaps even more than a hardware RTA. You must first understand the science of audio measurement, but you can look at it as an educational tool.
Rob
Rob
