My computer is making a buzzing noise
Discussion in 'Archived Threads 2001-2004' started by Thi Them, Mar 15, 2002.
  1. Thi Them
    Thi Them Producer
    Apr 20, 1999
    3,649
    It has been like this for a few weeks. Sometimes I hear the sound and other times I don't. A few times I turned on the computer and it made a loud, hoarse sound. Does anyone know what it could be? I'm thinking maybe its the fan.
    ~T
  2. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    Most likely one of the case fans.
  3. Colin Dunn
    Colin Dunn Supporting Actor
    Oct 10, 1998
    725
    6
    110
    Colin Dunn
    It may be something getting into the case fan blades - causing friction and the buzzing. Or the case fan might be setting off a resonance that makes the entire system buzz.
    If you rule out those two, your hard drive may be on its last legs - though they usually emit a high-pitched whine instead of a buzz when the bearings start to go out...
  4. Thi Them
    Thi Them Producer
    Apr 20, 1999
    3,649
    Thank you. I recently had my hard drive crash on my old PC, and I don't want to have another one this soon.
    ~T
