Clay Autery
- Oct 23, 2000
Working name is "Coffee Table Sub" due to my obligation to produce a new coffee table for my wife, need for a sub cabinet for my new Tempest driver, and the need to conserve floor space in my HT room.
The link below is to a view of the plan from the top down. I am maintaining the Vented Adire Alignment but massaging the dimensions to achieve the desired shape.
Top Plan View
I am going to build it as follows:
1) double thickness 0.75" MDF all around.
2) internal bracing
3) plate amp box in the bottom center (so I can add a plate amp later, or take it out and seal the wire pass-throughs if need be.
4) down-firing driver
5) 2 FP3 ports x 11" as spec'd in the Adire Vented plans.
6) Not shown: The inner top and outer top will be outside caps. The outer top will overhang all sides by 1/2" and be under-routed with a 1/8" round over and probably be veneered with maple (or cherry.... spouse choice)
7) Not Shown: Inner and outer bottoms will be inset to the ends and sides.
8) Not shown: All internal braces will be perforated (probably with 4" diameter holes).
The current outside dimensions of the sub are 54" length (including 1/2" overhang) x 24" (including 1/2" overhang) x 22.62" (including 4" legs with inset ball-bearing transfers at the four corners to make it possible to move).
The internal dimensions are 50" x 20" x 15.62", and after subtracting all volume reductions, I am right at 214L.
Here's the questions: I need to reduce the internal volume reduction by 620 in^2 so that I can reduce the internal height to 15" and the external height to 22" max.
Looking at the plan, and keping in mind that the box is 1.5" thick on all sides, would I be able to delete the longitudinal brace and one of the cross braces to gain some internal volume back to trade off for reduced cabinet height.
Currently, the bracing is set for panel spans of just about 9.75" as in the single width Adire plan, but if I used only three cross braces splitting the internal volume into thirds, would I have any problems with flexing... it is my gut feeling that I won't, but I'd like the opinion of some more experienced builders.
BTW, a close look at the plan would indicate that the amp box is only single thickness 0.75" MDF, but with it being reinforced with two braces in the current plan, or one brace across the center in the three cross-brace only plan, I doubt seriously if the 10.75 x 10.75 x 2.75" internal box will offer any flex problems.
Any comments or suggestions would be appreciated....
...and Yes, I know it is way over-built and will be very, very heavy... It should come in at right around 260lbs or a little more...
Top Plan View
2) internal bracing
