ash.1111
- Mar 5, 2009
- Ashley Irvine
Good evening,
My name is Ashley and I am new to the forums. I am currently in the process of turning my bedroom into a home theatre/bedroom.
I'm not sure if this is the right spot, but I am hoping to have this as my official thread for my purchases regarding the theatre. Oh, and placement/design advice! I will also post pictures of the process.
I currently have a Panasonic ax200e projector, Panasonic DMP-BD35 Blu-Ray player and a DETEC HD set-top box. All connected via HDMI. Although, no real importance has been placed with the type of HDMI cables used. I also have a Logitech 2.1 PC speakers system for the short-term. Oh, and a very flimsy pull-up projector screen. It's very old, and I plan to upgrade to a pull-down projector screen (80") within a few weeks. The seating distance is about 8-feet.
What type of screens do you recommend? I am looking for something sub-$400aud. It needs to be pull-down, though, because I have some doors over where it will be. No other walls will be suitable for placement and I may consider some kind of black blind behind the screen, as long as it's not too expensive and you feel it will be better.
Then once I have that, I'll move onto the sound system... fun!
Thanks! If you need pictures, please ask.
