My basshorn Complete
Discussion in 'Home Theater Projects' started by michael-e, Dec 15, 2003.
  1. michael-e
    michael-e Agent
    Sep 1, 2003
    37
    Incase u missed it in other forums..
    40hz , 143litres in volume and sounds GREAT [​IMG]
    My website shows expected response
    http://homepages.paradise.net.nz/quadroph 8" digitor horn.
    im going to use the lab12 later on (hopefully in january)
    This was a practise one ,and i learnt an important lesson-screw the flare in from one side while u glue the other-so ur screws hit the mark, i didnt,and some went into thin air and i had to redrill and screw while the glue set hoping id hit the spot [​IMG]
    link to save me typing it ALL out again and linking the images etc...
    link°°°°
    Cheers!
    [​IMG] [​IMG]
  2. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    Good work, what scares me from ever making a horn sub is the design.
    How did you come about making the taper and measurements? Were there plans that you followed?
  3. John E Janowitz
    John E Janowitz Second Unit
    Oct 30, 2000
    445
    Hey, you have my lab sub pic on your page. haha The two lab subs under the couch are ones I built for my friend Branson. They were in the living room at his house for a long time. One couch on top, the other couch in front of them. Pretty good impact for movies. :)
    I've been planning on making some small horn subs to have for weddings and stuff like that. What were the final exterior dimensions on this horn?
  4. michael-e
    michael-e Agent
    Sep 1, 2003
    37
