RichN
- Jan 15, 2002
I just got my MX-500 and I was wondering if there is a problem with it (or just with the person operating it). I got the codes to work for my TV, Audio, DVD and VCR1, but when trying to program the 3 digit codes for VCR2, I cannot get the remote to scan through the codes (I tried 2 different VCRs, and I can't get it to work by manually entering any of the VCR codes for Sony OR Panasonic). The "signal" icon blinks, but the codes don't change when I hold down the UP/DOWN buttons. It works on the other devices, just not on VCR2.
Another question is, I changed the name of "device" SAT to VCR3, but when I go to "page" for VCR3, the commands are not VCR commands. When I try to enter the 3 digit code for my VCR, it does nothing, which I think is because it is not a valid SAT code, correct? Do I need to do something other than simply change the name to get the remote to recognize that device button is for a VCR now and not a SAT? I have removed the batteries while I'm at work and will try it again when I get home, but I don't know what to do next if it still doesn't work.
RichN
RichN
