Music + 5.1 setup
Discussion in 'Archived Threads 2001-2004' started by Josh Davidson, Sep 12, 2002.
  1. Josh Davidson
    Josh Davidson Stunt Coordinator
    Dec 7, 2000
    81
    Hey, I have this nagging problem. I have a 5.1 setup, but whenever I play music I just get sound out of the front 3 channels and nothing out of the .1 output. I understand that is because the source is stereo, but I was wondering if there is any way to route the bass to the sub as well since my main speakers don't produce very good bass.
  2. SvenS
    SvenS Second Unit
    May 5, 2002
    257
    Use your receiver's Bass redirection feature and set your speakers to small and the lower bass will be redirected to your sub. If you have small speakers as you say this will garner a FAR better bass production as well!
  3. Josh Davidson
    Dec 7, 2000
    81
    Do you know if all receivers have this feature? My receiver isn't all that nice. It was part of a JVC HTiB. I've tried looking for that option in the setup menus and the manual with no success.
  4. AllanN
    AllanN Supporting Actor
    Mar 15, 2002
    950
    Make sure you don't have "Stereo Direct" mode turned on. This bypasses all the DSP's and bass management.
  5. Greg Haynes
    Greg Haynes Supporting Actor
    Oct 22, 1998
    577
    What receiver are you using?
  6. Josh Davidson
    Dec 7, 2000
    81
  7. SvenS
    SvenS Second Unit
    May 5, 2002
    257
    If it decodes Dolby Digital I believe it should contain Bass redirection... at least I have yet to hear of one that doesn not! Look for options like setting your speakers to small or large as that is what Bass redirection entails.
