Tammie N-S
- Jul 27, 2005
I'm starting out on my first home theater project. I won't be making my purchases right away, but I still need to configure the basic system now. We are doing some home renovation and I want to be sure to get as much into the walls as possible. The drywall goes up in less than two weeks! Before I can tell the electrician what cabling I want inside the walls, I need to have a plan for the system itself.
I have a somewhat limited budget and want to build a multi-zone system. I don't need recommendations for particular brands or models yet (altho if you want to throw that my way I will make note of it); at this point I just need to know that my plan will work.
Here's what I'd be connecting into my A/V receiver:
Video Inputs:
* Cable (digital comcast)
* Tivo (already have it)
* DVD (will get a new progressive scan)
Audio Inputs:
* DVD (for CDs)
* XM Radio (already have it)
* (Plus the AM/FM Tuner from receiver, obviously)
Other Input:
* Playstation
* I really want to be able to get tunes and photos and home movies etc. off of my PC. But I am not ready to take the full plunge into a Media PC. For PC connectivity I'm thinking of using this nifty $100 gadget I found called MediaMVP from Hauppauge.
Here's my zone plan:
Zone One (the home theater itself):
TV (right now I'm leaning towards the Panasonic TH-42PD50U 42in Plasma . . . but not really interested in starting an HD vs ED war here
Surround sound (I'm thinking 5.1)
Would also like to link in two speakers on the porch on that same zone (you can see the TV from the porch)
Zone Two:
Six (pair) Speaker Selection System
(I was looking at the Russound SS-6 IMPEDANCE MATCHING/6 PAIR SELECTOR)
1. Basement pool room
2. Basement play room
3. Kitchen
4. Back Yard
5. Porch? (I'm thinking that for max flexibility I would need to have the porch on both zones)
6. Open
Incidentals:
I will also have a TV in the basement; the soon-to-be demoted 27 inch tube. It will have the digital cable set-top box. It doesn't seem worth the cost to link it to the full system. However, I saw YANG (yet another neat gadget) for $140 that will send the signal (wireless) from the one TV to the 2nd. I can't post the link since I'm new to the forum; it's RF Link, and I found it at amazon.
If you're still reading, THANKS. I welcome general opinions. But mostly I have the following questions; answers to one or more of these would be most welcome!
1. It seems impossible to anticipate the location of the surround sound speakers when I don't have any of the equipment, furniture or even at this point the floors walls or ceiling. I'm thinking of having the electrician drop speaker wire to a jack in the general area where each speaker should be, then I can run a short wire from there when fine-tuning. Does that make sense?
2. If I set up zone 1 for the home theater and zone 2 goes to the speaker selector . . . which input can be directed to zone 2? Sounds like it's pretty standard in a mid-range a/v receiver that zone 1 is truly "a/v" but that zone 2 is strictly audio. Does that include the audio portion of something that is "a/v"? If MediaMVP connects to the a/v receiver via an S-composite and stereo audio cables, will I be able to send the MediaMVP audio through to zone 2? I'm assuming that this would be analogous to being able to play a CD in the DVD player and the audio for it would (should, I hope) be able to go through to zone 2. I hope I worded that question in a reasonably intelligible fashion. This is really my most pressing question.
3. If I want the porch to be able to play either the sound from whatever's playing in the home theater OR the audio that's running through to zone 2, do I need to have four speakers in there, two for each zone?
4. Pardon if this is a really dumb question, but can you play the same thing through zone 1 and zone 2? E.g, if you're having a party and just want all the speakers to play music, can you send the same music through the surround sound theater speakers and all the zone 2 speakers?
5. It seems that it would be important to be able to control the volume or at least have mute capabilities from within the remote room. My basic understanding of speakers is that there are "active" speakers with their own amplifiers and that those are either small (e.g., computer speakers) or more expensive high end speakers. But do passive speakers ever come with a "mute" button? It seems that this would be easy to implement; the button would simply (temporarily) break the circuit. However, in my quick web searches I didn't see anything like this.
6. I have some time to assemble all my toys; I anticipate that I'll be putting it all together in October. Any bargain hunting sales-watching advice? Just found the "shopping/buying/choosing" section of the FAQ and I'll check that out of course . . .
Thank you so much for any advice you send my way!
--Tammie
Video Inputs:
Audio Inputs:
* DVD (for CDs)
Other Input:
* Playstation
Zone Two:
3. Kitchen
4. Back Yard
6. Open
Incidentals:
--Tammie
