Multiple vents / length per...
Discussion in 'Home Theater Projects' started by ColinM, Oct 2, 2003.
  1. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    This is something I've never really understood - -
    In WinISD, If I model a sub (Shiva) with 1 port, 4" dia, 5ft3 tuned to 20hz, length = 13.62.
    2 ports in the same config, all else being equal, yields "vent length 30.17". I have asked before, and all responses say that that's 30" for EACH port.
    Now, looking at some recent production subs, like SVS's box types or the VTF-3, there are multiple ports, but not nearly enough room for vents longer than maybe 18" each. Of course I don't know the driver parameters, but would those parameters be enough to be able to have short multi ports?
  2. Phil~E~Guy
    Phil~E~Guy Extra
    Jan 30, 2003
    16
    Hi Colin,
    WinISD has two programs, beta and alpha pro. The alpha pro version will show the tuning graph. You must maintain port velocity below 5%. Port air velocity greater than 5% could add noise.
    So here is your answer (no port size or length is being said here).
    One port may need 5" to maintain 5%.
    Two ports may need 10" to maintain 5%.
    Two ports would let out to much air, port air velocity would rise above the 5%. To decrease port air velocity to 5% would require more port length (both ports). This increases resistance of air flow through the ports.
  3. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,779
    493
    9,110
    They just accept a higher tuned frequency for the enclosure in their design as a trade-off for the form factor.
    The more cross-sectional area is used (multiple ports), the longer the port will be for the same target tuning frequency. That just how the math works out.
