PeterK
- Jan 14, 2004
I have two speakers that I want to to hook up to the rest of my system.( which is a HT 700 panasonic home theatre in a box system) Each of these speakers has a 7 inch sub. I know thats not much of a sub for some of you guys but i find it just dandy. I want to hook up these speakers the only thing is that sub is where all the speakers wire come from. ( there is one cable going from the receiver to the sub which is about an inch wide at the connectors and has two rows of pins inside)Hopefully someone know what kind of cable that is. The receiver nor the Sub has a Sub out so i need to know how i can split the signal? Is there some sort of splitter that separates the cabel described above or if not I would need to get into the bass to run a wire to the other speakers (Not my first choice)
Thanks fo the advice
Peter
Peter
