Multiple sources at same time?
Discussion in 'Archived Threads 2001-2004' started by DanHughes, Mar 18, 2003.
  1. DanHughes
    DanHughes Auditioning
    Mar 17, 2003
    3
    I've had my new home theather system installed for over four months and everything's been running smoothly. However, I have found one major annoyance with having everything routed through my receiver (Pioneer VSX-D811S):
    I can't watch TV or play Xbox while listening to an audio CD. Or do anything that involves playing multiple sources at the same time.
    Even on my ancient Aiwa system from college, I was able to do this.
    Is this a limitation with my receiver (or all newer receivers) or am I completely overlooking something simple?
    Dan
  2. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    i'm not familiar with your receiver, but i know my onkyo has that capability.
    here's how it works on mine
    1. switch to video source
    2. switch to audio source. the picture stays on video, but the audio changes to your new input
    maybe you could try those steps. does the manual say anything about that capability?
  3. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    I don't think most Pioneer units can do it- I've owned 3, and non of them did it.
    I'd check the manual though.
    -vince
  4. DanHughes
    Mar 17, 2003
    3
    Absolutely no mention of it in the manual. Ted--that's what I've been trying to no avail. The receiver just switches and begins looking for both an audio and video feed.
    Looks like this is a Pioneer thing. Bizarre. For a real reviewed receiver, I figured this kind of flexibility would absolutely be included.
    I guess I'm out of luck. Even one of those $50 component switches won't give me this capability, correct?
  5. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    Ok, I'm confused. If you are watching TV what do you want your CD player on for? Two audio sources playing at the same time?
    Glenn
  6. DanHughes
    Mar 17, 2003
    3
    I'm not looking to have two audio sources active at the same time--I just want to use audio from a different source than the video input.
    Listen to music and watch your local sports team?
    Play Xbox and have your XM radio on?
    Pretty simple stuff that's apparently not doable on my receiver.
  7. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    bogus dan - looks like you're out of luck.
    a component switcher wouldn't make a difference. the receiver still wouldn't be able to route out the signal...
  8. Glenn Overholt
    Mar 24, 1999
    4,203
    I just wanted to make sure. Of course there's a way. Disconnect your component cables from your receiver and go out and spend $10 or so on an A/V switcher. Use it to change your component sources, and then you can crank up the receiver for the CD player!
    Glenn
  9. Greg*go
    Greg*go Supporting Actor
    Jun 14, 2002
    941
    I have a Pioneer receiver and figured out a crude way to do it while watching sports.
    I turn the receiver onto the video source, then switch the "optical 1" input (which is what my cd player is hooked up to)to that source. It takes all of 3 seconds to switch with the remote, and whem I'm done, I switch it back to CD.
    But you can only switch the digital audio inputs around, so if you don't want to listen to one of them, you're out of luck.
