Multiple Console Racing Wheel
Discussion in 'Archived Threads 2001-2004' started by WilliamZ, Jun 24, 2002.
  1. WilliamZ
    WilliamZ Agent
    Mar 15, 2001
    43
    Can anyone recommend a wheel that can be used with mulitiple systems?
    a) xbox
    b) Dreamcast
    c) pc - low priority
    Anyway I would like a wheel for the great racing games on the xbox and dreamcast, but I dont want to buy two.
    Thanks in advance
  2. Dave E H
    Dave E H Supporting Actor
    Apr 23, 2002
    829
    I own an DC & and Xbox (and a PC too). I've got the Mad Catz wheel for the DC and am buying PGR for Xbox one of these days. Instead of rebuying an Xbox wheel - especially since the xbox wheel looks mechanically identical - I just ordered a DC-xbox adapter for Lik Sang - should be here anyday now. Will let you know how it goes!
  3. WilliamZ
    WilliamZ Agent
    Mar 15, 2001
    43
    Great, I look forward to reading your comments
    In the meantime, does this adapter function both ways
    a) Dreamcast controller to xbox
    b) Xbox controller to dreamcast
    Just wondering if I would have to get a dreamcast wheel or if I could get a *newer* xbox wheel
  4. Jeff P
    Jeff P Agent
    Jun 18, 1999
    41
    William,
    You might check www.actlab.com
    I have the racing system and it is built solid and has lots of add-ons!!!
    Good luck!!
  5. WilliamZ
    WilliamZ Agent
    Mar 15, 2001
    43
    Jeff
    Thanks for the link. Looks like a promising system although there are plenty of complaints that the wheel currently does not support the PS2 or xbox.
