Multiple analog inputs? (SACD/DVD + HTPC)
Discussion in 'AV Receivers' started by Joseph S, Aug 30, 2003.
  1. Joseph S
    Joseph S Cinematographer
    Dec 23, 1999
    2,862
    Well, I currently own the Denon 3802 and have added the Pioneer 563A for DVD-A/SACD purposes on my analog ins. However, I would like to use a HTPC with a M-Audio Revolution Audio Card for my DVD/HDTV needs with the same set of ins.
    The problem is how do I incorporate two sets of 5(+).1 analog outputs with a receiver that has only one set of inputs?
    Has anyone come up with a solution for this aside from running two separate receivers?
    Is there a receiver with multiple ins or a preamp that can do this for me?
  2. FeisalK
    FeisalK Screenwriter
    May 1, 2003
    1,245
    Check this page. Brian is using the MCM switch, I think. For 5.1 channels i guess you might need a pair of them?
    Is the DAC on the M-Audio that good that you don't want to connect it to the receiver using a digital (coax or optical) link?
  3. Brian L
    Brian L Cinematographer
    Jul 8, 1998
    2,904
    10
  4. Brian L
    Jul 8, 1998
    2,904
    10
  5. FeisalK
    May 1, 2003
    1,245
    I seem to recall reading about some high-end preamps having a number of inputs which can be switched around as you like - for example 12 analog inputs you can use 2x5.1 and 1xstereo, or 1x5.1 and the rest stereo.
  6. FeisalK
    May 1, 2003
    1,245
    Lexicon MC-8
  7. Shawn Fogg
    Shawn Fogg Stunt Coordinator
    Oct 5, 2001
    223
    "The SF and other vendor who's name escapes me are in the $400 range."
    Mine is a little less then half that actually.
    Shawn
  8. Peter Jessee
    Peter Jessee Stunt Coordinator
    Sep 25, 2000
    149
  9. Joseph S
    Dec 23, 1999
    2,862
    The Denon AVR-5803 definitely seems to fit the task perfectly. Unfortunately, at $3000 it's out of my league at this point. I was hoping for maybe a $400 or less auto or remote switched device like the Audio Authority component/dig video items.
  10. GordonL
    GordonL Supporting Actor
    Feb 14, 2000
    771
  11. Joseph S
    Dec 23, 1999
    2,862
    Looks like it's not available until the middle of the month, but...
    it looks like a winner since I'm not planning on having a 7.1 setup or picking up a $3000 receiver for a few years. Remote option is actally another $100 for $550. Switches 3 components so there's room to expand. [​IMG]
    Thank you.
  12. Cary P
    Cary P Stunt Coordinator
    Jun 21, 2000
    124
    I didn't realize the MC-8 had the capability to accomodate two 5.1 inputs by reconfiguring the analog stereo inputs, that is a nice feature I'd like to see on more products. But the MC-8 is way more than I'm willing to spend on digital surround processing.
    What I'd really like to see is more high quality, multi-channel analog preamps introduced. A tube-based analog preamp with two 5.1 inputs, a home theater bypass input, and maybe two or three stereo inputs with one tape loop would be perfect for me. That way I could enjoy my high quality SACD, DVD-Audio, and vinyl sources to the fullest, and just get some cheap HT receiver with all of the latest digital processing for the occasional DVD movie and regular TV watching.
    This would be the best solution for music lovers like myself who don't watch much more than one or two DVD's per month, and who are not too concerned with having the utmost sound quality when watching TV programming.
  13. george king
    george king Supporting Actor
    May 29, 1999
    625
    I think the Adcom 880 has two sets of inputs.
  14. Mark All
    Mark All Second Unit
    Dec 10, 2002
    256
    The Sony STR-DA4ES and STR-DA7ES have dual multi-channel analog inputs. Prices are low.
  15. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    The new Sony 5000ES also has 2 multi-channel inputs @ $1500 MSRP, not sure about the 3000ES.
  16. Dan Driscoll
    Dan Driscoll Supporting Actor
    Aug 1, 2000
    937
    2
    The McCormack MAP-1 has dual 6 channel inputs and is a very nice analog pre-pro to boot.
  17. Andy_A
    Andy_A Second Unit
    Feb 19, 2001
    477
    also the Sony str-db1070 and the str-de1075 both have 2 sets of multi-channel inputs. the str-da1es does not but the 2, 3, and 4 es receivers do. Hope this helps
