sendmorebrains
- Dec 30, 2006
- Jude
HI !
Currently my set up has the D812K driving my 7.1 set and 3 other amps chained on the SUB OUT jack running my 8 various sized subs ( 12"woofers x2 )(12"x2)(10"x2)(8"x2)
Heres why Im asking:
I can get access to 4 identical integrated amps running @ 200w total w/ pre ins & outs RCA jacks in the rear of them.
Hence I can use the 4 amps to run fronts-centre-surround sides-surround rears by hooking all of them up to the rear of the D812-K.
QUESTION:
1. Would I notice a significant change in sound quality using the 4 amps instead of using the D812K amp ? In other words is this set up worth the pain to wire and install ?
2. Would wiring this way allow me to still use the volume control on the D812K for all 4 amps hooked up to the D812K ?
Just to give you a bigger picture as to why Im thinking adding the 4 amps - my entire HT set right now is:
Monitor:
Toshiba 62HM94 62" DLP
Audio Receivers’:
7.1 AVR Pioneer VSX-D812K (100w x 7) Powering Front L&R speakers - 2 Center speakers – 2 Side L&R – 2 Rear L&R speakers
Pioneer VDX5000 (100w x2) Powering 2 – 12” subs 4cubic foot boxes (30hz) in the rear of sofa.
Sherwood RX-4103 (105w x 2) Powering 2-12” subs 2.8 cubic foot boxes (30-60hz) front
Kenwood KR A4020 (80w x2) Powering 2 – 10” subs 2 cubic foot (40-80hz) & 2- 8” subs(40-90hz) front & sides
Left & Right Speakers Home Built w/ 1” MDF & bracing Vifa 1”tweeters 6” Vifa Mids
Centre Speakers: Technics 110w & Polk Audio CSi25 100w
Gaming/Entertainment Media Consuls:
ASiD HDMI 3 imput remote Digital Switch box
HP Digital Entertainment Z-540 – DVD-R, 160g x2
Satellite – Captain 8000HD 600 plus channels + 40 HD stream channels (hacked open)
DVD –Toshiba SD 4990 up converting to 1080i
Sony PS3 – 60g w/ Blu-Ray Player
Xbox Elite 360 120g drive
Nintendo Wii
LogiTech Harmony 550 remote to tie all the loose ends up.
QUESTION:
Monitor:
Audio Receivers’:
Nintendo Wii
