multi room vs multi channel
Discussion in 'Archived Threads 2001-2004' started by joe rizzuto, Jul 1, 2002.
  1. joe rizzuto
    joe rizzuto Stunt Coordinator
    Jun 10, 2002
    140
    my reciever has a feature called multi channel input which i cannot figure out (how does it work?) vs my old reciever which has multi room, that was easy to figure out and i used it often to have music all over the house. i need help, what am i missing here with multi channel input?
  2. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
  3. joe rizzuto
    Jun 10, 2002
    140
    thanks vince, it's starting to make sense.
    i actually did read the primer when i first started to post here, great info btw, but did not find anything that fit the question for me. if i understand u, this is a forward looking feature for another hardware source for future use, like a sacd player, for example. yes?
  4. Vince Maskeeper
    Jan 18, 1999
    6,499
    Yep.
    There are basically 2 ways of connecting any "multichannel" audio source to your receiver. The main way is digitally- like how most people connect their DVD player. This passes the audio signal as a digital stream to the receiver and the receiver decodes it.
    But what happens if you have a digital source that is supplying a signal that your receiver has no decoder to handle?
    Well- in that case - you have to decode the signal before the receiver- and send the receiver the decoded six channel analog lines to be amplified.
    This, like you said, it a forward thinking option allowing you to handle new digital multichannel formats that were not around when the receiver was designed (SACD, DVD-A, ETC.).
    -Vince
  5. joe rizzuto
    Jun 10, 2002
    140
    i have seen the light, thanks
    hey, the voices have stopped now, great...
